solarboy said:
My first post here so I am hugely underqualified but...... are you sure you haven't got a water leak hidden by an automatic fill valve?
Thanks for the assistance. I don't have an automatic fill valve, and also have a solid electric cover, so no water evaporates. The only time I have to add water manually from a hose is when I backwash the filter.
I think Chem Geek's diagnosis makes the most sense, as I added a lot of stabilizer, which all disappeared, which I then had to follow up with a lot of chlorine.
Ever since shocking and getting the chlorine up to 32ppm last week, FC has been holding and slowly decreasing. My SWG has been off for a week and here are my current stats:
FC: 14
TC: 14
TA: 110 (still working on getting this down, adding 4 cups of acid to get pH down, then aerating. This is a LONG process, taking me about 2 days for every drop of 10 in TA)
CYA: 70
CH: 300
I think I am now on the right track, but also have some questions for anyone still reading:
- Any thoughts on the automatic chlorine level self adjusting SWG from Zodiac called the TRi-Pro? It supposedly measures the chlorine level in the water and adjusts its output based on that.
- Anyone have any thoughts on the shelf life of sealed bottles of bleach, sealed bottles of muriatic acid, and sealed boxes of Borax? Don't think I will get around to doing the borates this summer.
Thanks again for all the help and ideas.
