santacruzpool
Honestly, besides the FC being too low at 3, the rest of your numbers look pretty good for now. PH is fine in the 7's - don't touch it as it will rise up naturally. When PH rises over time, and you add more acid to lower it, the TA will slowly drop - there is no need to focus on the TA level at this point. When the PH hits 8, add acid to lower it to 7.4-7.6.
CYA should be rounded up - which means you have 50 and your FC should be at a Minimum of 4 - and your real target is 6-8, so you are low. I would add some Liquid CL to bump that up, and add it everyday until you get your SWCG running and able to hold the FC level.
50 CYA is just below the recommended amount for a SWCG pool - you could raise it now or wait until everything is up and running. Once you get a feel for everything and the SWCG is working you can raise the CYA.
For chemicals you just need Muriatic Acid, some CYA, and Liquid Chlorine (Shock)...
The Free Chlorine and Cyanuric Acid Relationship
Managing your cyanuric acid and Free Chlorine levels is key to stabilizing your pool. Learn how these two items affect each other.
www.troublefreepool.com
