Pool Calculator MIN/MAX vs GOAL RANGE
MaxAcceleration
36
Caledonia, IL
Does anybody know why the pool calculator doesn't update the "GOAL RANGE" when changing the CYA? I changed the CYA from 25 to 80 just to see it change the GOAL RANGE but it never did. (Note: I normally keep my CYA at 40, I'm just testing the calculator) You can see at the bottom the MIN and TARGET get updated correctly, but why not the "GOAL RANGE"? MIN/MAX is 6 to 11 but the GOAL RANGE remains at 3 to 7. I even tried refreshing the page and that didn't help. They are both referencing free chlorine levels, so I don't get it. What am I missing? Thanks, Jamie
Cause Pool Calculator no longer maintained regularly.
Use PoolMath instead - App available for iOS, Android and Windows.
The Old PoolMath Webpage is also available using the link at the bottom of the page here in the forum.
