Pool Build in Rural North Texas
wuthrirc
23
Wichita Falls, TX
Pool dig April 18, 2019. Freeform with tanning ledge and 2 benches (approximately 96 foot perimeter). Shimmerark 2" flagstone for coping. Noble Tile NWGF Sankai 678 and 178 (6-inch and 1-inch). Quartzscapes Aruba Sky Reflections applied June 30, 2019.
Hi!! What a sweet pool! I love it's shape and the tiles you used!
The basic test kit TF-100 works for any pool. For a salt pool you add a salt test. Just know if your SWG is happy that is all that really matters in the end. Now if you want to get extra fancy you can add the Speed Stir. It makes the testing even easier! For now plaster you will enjoy the Whale Wall brush. The tail helps push the brush so you don't have to work as hard to brush.
I have a set of links I put together for new pool owners. It is a lot of info but will start to make sense as you use it.
Print these out:
Bookmark these:
Trouble Free Pool
Kim:kim:
Reactions: wuthrirc
Looks fantastic! Ours looked the same a few weeks ago.
I would suggest
And
Texas temps are getting higher...
And
https://mmgtx.com/docs/PTI-Start-Up-Maintenance-Procedures-Salt-SWCGS.pdf
Happy brushing!
I did order the whale with my kit. ?
Print these out:
Bookmark these:
Trouble Free Pool
Kim:kim:
Thanks so much for the information!
I would suggest
And
And
Happy brushing!
Thank you very much! Sounds like we need get the whale (although I'm not even sure what that is yet!)
Print these out:
Bookmark these:
Trouble Free Pool
Kim:kim:
Here is our start up page: Start-up New Plaster - Trouble Free Pool This is good guidance on what to do. Since you do not have a pump yet you can walk around the pool with a straw broom or boat paddle a few times to get the water moving good then add the chemicals. Once you add the chemicals make sure to brush the pool real good to make sure they are mixed in good.
I would say use a submersible pump BUT do not want that on your brand new pool. I am VERY worried it would mar the new plaster :(
Reactions: wuthrirc
