We recently completed our pool and had standard water/fire bowls installed.
There is discoloration that’s normal water will not remove. We want to fix the problem but are hesitant to try cleaners. Has anyone else had this issue and what did you use to clean them? The bowls seem to be a concrete bowl that is painted. Attached is a photo of the bowl with the discoloration.
Thank you!
Thank you!
