- Jul 15, 2012
- 634
- Plaster
- Hayward Aqua Rite (T-15)
Pool has been running since first week of April with heaters bypassed. Opened the bypasses today and both heaters failed to work. Each heater is a 2011 Raypak 406A with 3-4 year old circuit boards (revision 1.08 and 1.07 digital). I will outline each separately as the problems are different, and I'd appreciate any suggestions on each problem for next steps. Last two year the heaters fired up like a charm.
Pool Heater:
Heater goes to spark when I turn on the heater at the Jandy control (it says firearm sw alert until it goes on, which is normal). But it never ignites. I hear it trying to start, but I do not see anything lighting inside when I remove cover of heater. Initially I had tried to start heater with the gas valve inside the heaters switched to off.But turning it on did not correct the problem. Seems to me it's either an igniter issue, or a gas issue. As I just switched the gas on this morning at the main valve, I will give this heater another try later in day. But what would be the next step in diagnosis?
Spa Heater:
Heater says open sw and not firearm alert when off or on. That suggests a water flow issue. But I hear water flowing through heater. And I do not see any water leaking out from it. Variable speed pump is on a pretty high speed although I could turn up. Any other suggested things to try?
Thanks in advance...
Pool Heater:
Spa Heater:
