Polyquat goof before closing
ba67
100
Southern Kentucky
When I added the polyquat to my pool this morning, it came out of the bottle much faster than I expected and I ended up dumping the majority of the 32-ounce bottle into one small area in the deep end. I only got about 3-4 ounces of the bottle into the shallow end. I ended up adding 10 more ounces of polyquat to my pool than I needed so I could get some of it into the shallow end. I’ve been brushing in the deep end but I don’t know if it is doing any good. Closing is this afternoon so I will only be able to run the pump 3 more hours. Since I’ve got more polyquat in the garage that was left over from last year, should I add some more to the shallow end since I was only able to get 3-4 ounces in there? I know that large doses of polyquat lowers chlorine levels so I wasn’t sure if I should add more or not.
You will be fine the way it is. Just circulate and stir up the water with your pool brush the best you can.
