Polaris P955 Has Power Then Turns Off
JeanZ1
161
Newark/DE
CircuPool RJ-60 Plus
I have a Polaris P955 that powers up OK, but as soon as I press the start button, it turns off. Any ideas or must I take it to Leslies for diagnostics?
If that is the tubular screw-in plug the plug itself is the culprit. Mine does it as well. The solution is to clean out the contacts with a pipe cleaner or thin wire or something that can rough up the copper contacts. You can also unscrew the plug end and clean those contacts that way. Once it is cleaned and working, use dielectric grease on the parts to hopefully keep it free of corrosion for awhile. I have to clean mine annually and even still sometimes it fails. I jiggle around the plug and get it back working again.
Reactions: kimkats
Did you get this resolved? My 9350 was giving the single blink led error after moving forward a few feet. I opened the barrel connector cleaned out, tightened it, and reattached it and now as soon as I press start it turns off and I have to unplug it for a few minutes. I just replaced the barrel connector completely and doing the same thing.
