Hi
I purchased a house with a pool last year and did a lot of reading from this forum to get going. The pool came with a Polaris P935 that was 3 years old and this year stopped working this weekend. Took it out of the water and after opening it, found water ingress into the motor block.. After drying out the parts and liberal use of electronics cleaner, i've got the robot running again in the garage. I think the o ring failed but i cant find a replacement anywhere. The company sells only the whole motor block yet a 85cm 3.5mm oring would probably solve the problem.
Anyone used any other way of replacing the oring by using another application or source? Help would be appreciated.
Thanks
SC
Thanks
SC
