Was hoping someone could answer a question for me on the Polaris Freedcom (if you own one already!) I want to use it to clean ONLY my overflow basin (disappearing edge) which is about 1,600 gallons because it regularly just turns into a giant skimmer with a lot of Crud on the floor of it.
1. Is it possible to set a customized cleaning time of only 15 or 30 minute for a cleaning job? (again the area it cleans is small, 1,600 gallons only, so it doesn't need to run hours --- 15-30 minute is all it should need to clean the given space).
2. Is it possible to turn OFF the 10 minute "come to the surface" after a cleaning job? (I'd rather leave mine in the overflow basin for 3-5 days at a time and not removing it with each job)
3. I'm hoping that with a 15-30 minute customized run time, I can leave it IN the overflow basin for about 3-5 days, running it 1x per day from the App, and without having to remove it every day. Then take it out ever 3-5 days to clean the filter AND put it on the charger. Is that feasible?
If anyone can answer those 3 questions, I'd appreciate it. I spend 15 minutes each day manually vacuuming my overflow basin with my WaterTech cleaner, I just want to save myself 15 minutes every morning by letting the robot clean the overflow basin.
