maddscot
0
Another "tester" of the Polaris Freedom here. I was tired of the seemingly endless issues with our pressure based cleaner and really was not an advocate of spending the $$ for a robot type unit. Did a ton of research here, there and everywhere. Was leaning to a Dolphin unit I decided to give the Polaris Freedom a go. This decision was after reviewing and discussing these robots with various pool supply stores, pool builders/companies and folks who run their own service company (we follow the TFP methods and I am the pool guy). Key considerations I looked at where:
The Dolphin corded units were my first choice initially until I looked into cordless. Limited choices for sure and as others have said, the cordless option was very tempting. Now had to look at performance (based on corded versions and companies support) and other features. I really wanted a simple unit, no need for iRobot/Roomba room (pool) mapping, cameras, apps to tell it where to go, and so on. With that I decided after about a week to go with the Polaris, and if it did not work out, then so be it, and corded would be the fall back (most likely the Dolphin Nautilus line).
Got the Polaris Freedom, and it was unboxed and set up in no more than 10m. Base is simple, no bigger than the base of the robot, plug in, place robot on charger, set up app and it was ready to go. First run in the pool and it worked far better than the previous pressure based units. Pool is a 25x18 "kidney" shape with spa and is 5.5' deep (approx. 15k gallons). The unit ran its full cycle (2.5 hours timed) did not seem to miss any locations The first run in the pool had a good amount of dirt, leaves etc. due to only manual vacuuming twice over two weeks. Pool was subject to winds, a couple of storms, dog who loves to swim and some spa use). The next two runs were the same as well as a waterline only check. Unit worked as advertised, collected a bit more than I expected especially after running only every other day.
So four runs of the unit, each, with the exception of waterline, running 2.5 hours for total pool (waterline, sides and bottom) and charge time to full within 3 hours (at least based on the unit icon and app). Easy to place into pool, starts once it hits bottom, cleans very well IMHO, comes to side of pool when done (changes locations for a couple of times and waits for pick up - had to 1 time pull it up with the included hook as we were not home), easy to clean basket, wash and towel off to put it back on base. I'm going to say so far, really good. Will post up if issues come up....
- Tread style unit
- Ease of use / good warranty
- Med and up sized collection bin and ease of clearing/cleaning
- Ability to collect leaves along with cleaning
- Wall/Water line cleaning
- Storing and size of entire robot and related items
