- Nov 5, 2008
- 2,598
I need some help with my Polaris 380. The wheels are not turning. The booster pump is running, there is a strong flow out of the pressure relief valve where the line conects inside the pool, there is some flow out the back of the unit and some out the tail but the tail does not whip around. There is a little flow up the suction part of the unit but not much, I think it typically has much stronger flow there.
When I turn the wheels, they all turn together. I opened the housing and the paddlewheels inside seem to still be connected to the axle correctly, that is not broken, although I was surprised at the number of turns it took to make the wheels turn.
I can't see what is wrong. And, I don't really have a local pool store that I trust all that much to just call to come take a look. I don't suppose that if I took it to a store they could see what is wrong, or could they?
Is there anything I can do on my own first?
