First off, not sure which one I have, as it came with the house and it is at least 25 yrs old probably. Anyway, the problem is that the Polaris seems to move around the pool but the debris isn't being sucked up into bag. Bag doesn't even inflate like it used to do. I've replace the swivels that were leaking.
The pressure relief valve is tightened all the way down, but some water still sprays out of it. That has been replaced in the last few years, I believe.
The back-up valve seems to work fine but some water also sprays out of the port, even when not in back up mode. Is this normal?
In the backup mode, a steady stream comes out. When I blow air into the end of the back-up valve, I can hear gears spinning. I can't unscrew the valve to look inside. It probably has never been opened.
The 3 little ports on the bottom of the Polaris seem to be spraying water into the bag, but bag just lays limp.
Any ideas? A new back-up valve? If so, are the 360 & 380 interchangeable
Thank you
Thank you
