- Dec 20, 2020
- 2
- Vinyl
- Pentair Intellichlor IC-40
I have a new (year old) pool that came with a Polaris 280 booster pump cleaner. After a year and change of use, I've noticed that the 280's bottom is scratching the liner at the transition from the angled portion beginning the deep end, to the flat shallow end. The liner is showing some white marks, where the 280 is scratching off the printed pattern; and the bottom of the 280 has slight marks on the bottom of the shell, between the two large drive wheels.
Neither Polaris nor Loop loc had much to say when I called them about it, other than say it's not a covered warranty issue. I purchased the tank Trax kit to try on the 280, in hopes that it will help. Has anyone else seen this happen before? I'd like to avoid buying a new cleaner, but it's a small cost compared to a new liner.
