I installed a new Polaris 280 last September to replace my 5YO crappy Kreepy Crawly. Worked great until just recently. The back wheel is not making contact with the floor of the pool. Therefore it remains in the deep end and is not crawling up the walls of the pool. It continues to suck things up. In fact we had some storms here recently which put a lot of leaves and debris in the pool. The bag of the Polaris filled up quickly. I'm just not getting the pool coverage that I need since the back wheel isn't propelling the cleaner at all.
I've tinkered a little bit with the head float. I moved it back which now seems to be the wrong direction. Either way the problem didn't get better or worse after I did that. I also made a thrust jet adjustment pointing it up which is supposed to increase climbing. That didn't make any perceivable difference either.
I've read threads on TFP about phantom pebbles and other blockage issues. I can't find anything like that in the system. I've also read about back-up valves stuck in the open position. I don't think I have that problem but for the live of me I can't unscrew the back-up valve to fiddle with it.
Thanks!
Thanks!
