- Apr 10, 2018
- 6,468
- Plaster
- CircuPool RJ-45 Plus
Don't worry about the way it looks now. You should put a couple coats of paint on the PVC to protect it from UV exposure.
The corded side of the cell is the inlet side. Just flip it around.
The elbow after the cell appears to be a DWV (Drain, Waste, Vent) fitting, not rated for pressure applications. If so, I would swap it our before continuing on with plumbing.
Did you test salt level before adding salt. It's common for pools to have existing salt from other forms of chlorination and chemical additions. Mine was around 1200 after three years of non-SWG chlorination.
