OrangeAndBlue
- Aug 19, 2017
- 128
- Plaster
- Hayward Aqua Rite (T-15)
They won't be small forever but they will use the pool for years. Safety is a big concern with kids of course so do what you are comfortable with.
I think 3.5 - 5.5 - 4 would be good for a sports pool
Mike, I feel for you. It's hard to figure all of this stuff out, and a pool is a big expensive project. My guess is that for many people it's the biggest, most expensive home improvement project they've ever undertaken.
I've owned a number of pools, one with a SWCG and others without. One had a built in cleaner system, actually built into the walls rather than the floor, this was some old school stuff.
Like you, I'm planning out a pool build right now. In certain areas/markets, pool builders can be very resistant to salt pools. Where I live, some builders won't install them, others refuse to warranty the pool and make you sign a release-- one even told my wife that salt water pools cause cancer, I can only wonder what he thinks of the ocean. The builders where I am strongly push the ozone/uv/chlorine puck feeder system. When you read opinions from this site, you may find a lot of folks strongly supporting the use of a SWCG and offering advice that contradicts your pool builder, and it can be hard to know what to choose.
Having done both, I found the pool with the SWCG was far easier to manage, and I'm going to use a builder who will work reasonably with me on this. I didn't have problems with my pool pump burning out, and as others have suggested that isn't an expected downside of a salt system.
As for the in floor cleaner system, if you look into it on this site, there are certainly people who have them and love them. Reading those opinions is probably time well spent.
The old school cleaner system I had leaked terribly and it was really hard to get someone to fix it. The fix ultimately was to render the system useless and seal over all of the ports, and the cost was way more than the system initially cost. I looked into the modern systems with this upcoming build. For me, it seemed too permanent and too many holes and pipes in the bottom of the pool. I have a decent knowledge of boats, and one principle in making a boat easier to manage is to limit the number of things that go through the hull beneath the water line-- to a certain extent I want the same in a pool. It's going to have to a circulation system with suction and returns, enough to work well, but the closer I can get to having an solid concrete bowl the better, IMO.
Also, I had a robot cleaner recently and it did a great job and was easy to use. Way cheaper than an infloor system and I could replace the whole thing with 2 minutes and a few clicks on the internet.
As for corrosiveness of salt water, I can't say I understand the argument that you can increase the amount of salt in water and not have it make a difference on how that solution interacts with metals and other materials, but still it wasn't enough of a problem to make me not use it. Many people manage the pros and cons of putting a $50k to $100k boat directly into the ocean, so why should people who own $50k-$100k pools not be able to manage the pros and cons of a far less concentrated salt solution being in their pool?
As for the decking, we too are going with Sundek or Cool deck for this upcoming build. Travertine and flagstone installed where we are is about $30/sf, whereas the other materials may be less than half of that. Imagine 1000sf of decking and you can figure the costs out pretty easy.
I had KoolDeck before with my SWCG pool and no major problems there. We re-stained it after about 10 years, cost about $800, and it looked good as new.
Best wishes.
Mike, your pool structure is actually quite strong for Houston standards. 1/2" rebar at 8" oc is more than I saw in any of my quotes (maybe except one out of 10). Floors and walls at 9" is also thicker, most quotes we got speced 6" or 8" (you won't be able to check on easily - so you have to trust them on that). All this might cost a bit extra, but at least it shows that this pool builder is not doing things the cheapest way which is nice.
I second the recommendation to go with the SWG, my parents in law have it for 15 years and they have not had any equipment issues nor any issues with the pool coping.
PS: on sundek vs cool deck. When I did my research I found out that cool deck is a different product and did not hold up well, but that Sundek and other newer Spraydecks are a better material that will last (and with some touch up paint can easily be fixed). We just didn't have the extra $6,000 to upgrade to all travertine decking and figured with little kids it's probably a good option to get the most slip resistance anyway, so we will see how our spray deck will hold up.
I have a forum etiquette question. I am leaning towards signing with a different PB (thanks to rhawke's recommendation) than the original build list that I posted. I'd like for some of the experts on the forum to review the new/different equipment that this new PB will use. Should I just post that here or start a new thread and label it a build?
That's identical to the equipment we are getting. I remember your pool being quite large so if you want a lot of light at night you might want a second pool light. That will end up costing you quite a bit though, probably around 600 for the light plus a couple hundred for the electrician.Mike,
I see nothing that looks out of place to me...
I like the ET 8 with ScreenLogic, the IntelliFlo pump, and the 520 filter...
Raypak heaters seem to be the most favorite here... But plenty of people have Pentair heaters..
"If" you decide to go with Saltwater, make sure the ET comes with the internal power supply and the SWCG and valves.. It is a package deal and works better. That P/N is 520545...
Mike,
My pool and spa are pretty close in size to the one you're planning and I went with the IC60 instead of the IC40 Jim is giving you the part number for. My part number (same kit with a larger swg) was 521150. I bought it for $1799 from sunplay and the screenlogic w/ wireless kit for $369 and free shipping for a grand total of $2144 (not sure why my receipt's grand total is lower than the subtotal maybe there was a discount offered on the order page). I bought this end of last October when I was closing on my home and it was the least expensive place I could find...and cheaper than buying multiple things separately.
I think the ic40 is rated up to 40000 gallons and I read here on the forum that people recommend getting a swg at least double the size of your pool. So based on that "rule" you should still be fine with the ic40. Going with the ic60 means that it will have to run even less hours compared to the ic40.Ok, just heard back. They are using the 520545 that Jim recommended. The pool is 16-17k gallons. Should the IC40 be fine?
Mike, also keep in mind with the larger swcg cell you have future costs in that the replacement cell IC60 is about $130 more than the IC40. It's 50% larger but does it last 50% longer? I have no idea. If so, probably something to consider since the replacement cells are a lot of money.
IMHO if you can swing the few extra dollars I would get the IC60 however the IC 40 would be fine. The IC40 would just have to work a little harder. Hope this helps![]()
