Hi,
I’ve joined this site to get the best pool info around! I have been reading a ton on here and have a whole bunch of questions now. Thanks for any help!!!
I just received my shipment of my Aqua Leader Galaxy 15x30 Oval AGP from Pool Supplies Canada (only place that had anything in stock, nothing locally! I'm in Canada, BC)
So next up I need to pick the rest of my components. Looks like I will have to get most stuff off Pool Supplies Canada as most local places seem to have low stock or back ordered.
I’m having a pool company prep the ground and do all the of the pool install. They deal with Hayward and can get me some stuff if needed, but they said I can order equipment myself as well if want.
I will be building a deck around the pool as well.
My equipment was going to be installed under a 6 foot high covered deck/patio. Do I need a box/shed over any of the equipment or is open air fine?
Looks like a 15x30 (54" height) pool is approximately 15,000 gallons is that correct?
I’m hoping for the easiest to maintain setup I can get if possible. Here’s where I’m at so far for choices.
1) Sand Filter
Looking at 25”-27” Hayward Sand Filters (but open to others), as the larger sizes seems to be the most recommended on here.
The Hayward 25” SandMaster looks like in stock, is there a big difference between the SandMaster and their Pro series filters?
2) Pump
What models/sizes?
Most people on here seem to recommend a 2 speed over a 1 speed pump I noticed.
I’m Looking at the Hayward 1.5 HP 2 speed Turbo Flo 2 AGP pump
Is the Matrix 1.5 2 speed better?
Also was curious on the noise levels of the pump under the deck/patio.
3) Natural Gas Heater
What size? Seems like 200K-250K BTU is what is recommended is that correct? What models?
Was looking at the Raypak Digital 266,000 BTU Electronic Natural Gas Heater (Do I need cupro nickel?)
or
And the Pentair MasterTemp 250K BTU Low NOx
Is the Raypak not Low NOx? Like I mentioned will be under the patio/deck we sit on will this be a problem, or could move the heater if needed.
4) Salt or chlorine auto dispenser/feeder
Two different pool installers and one pool seller all told me to not do salt water as destroys the pump, heater, etc way faster, get salt residue on the deck is this really true? Most people on here seem to like salt.
Does something like the below Zodiac vision really work? Any better options for chlorine or other brands/models?
Zodiac Vision Pro Above Ground Chlorinator and Nature2 Vessel (With Cartridge) | Pool Supplies Canada
If salt what cartridges, etc recommended for my pool size? Is it correct to double it?
5) Other stuff I need?
What cover and probably roller systems are recommended?
Do I need an underlay mat if on sand? If so is this a good mat?
15 X 30 ft Oval Rhino Floor Pad 9 Oz | Pool Supplies Canada
Or any other recommendations for mats?
What about vacuums, poles, hoses, just standard stuff?
I’m assuming sand base is the best? Could do a concrete pad as well if better.
Am I forgetting anything?
I know these were a ton of questions so thanks for reading and help and suggestions can give is very appreciated.
Thanks!
- 54 inch tall steel coated wall
- All Resin components (Top and bottom rails, uprights, plates , etc)
- Salt Water Friendly
- Buttress-Free Oval System
1) Sand Filter
Hayward 25 inch Sand Filter | Pool Supplies Canada
The Hayward Sandmaster 25 inch sand filters incorporate the latest technology to ensure your pool is operating at its very best. From Pool Supplies Canada
www.poolsuppliescanada.ca
2) Pump
What models/sizes?
Hayward 1.5 HP 2 Speed Turbo Flo II Pump Above Ground | Pool Supplies Canada
Hayward 1.5 HP 2 Speed Turbo Flo II Pump Above Ground available with fast shipping online from Pool Supplies Canada.
Raypak Digital 266,000 BTU Electronic Natural Gas Swimming Pool Heater | Pool Supplies Canada
Raypak Digital 266,000 BTU Electronic Natural Gas Swimming Pool Heater available with fast shipping online from Pool Supplies Canada.
or
Raypak Digital 266,000 BTU Electronic Natural Gas Heater with Cupro Nickel Exchanger | Pool Supplies Canada
For both salt and environmentally friendly pool heating, look no further then the Raypak Digital 266,000 BTU Electronic Natural Gas Heater with Cupro Nickel Exchanger - available direct online with fast shipping from Pool Supplies Canada.
Pentair MasterTemp 250,000 BTU Low NOx Natural Gas Swimming Pool Heater | Pool Supplies Canada
The eco-friendly Pentair MasterTemp 250,000 BTU Low NOx Natural Gas Swimming Pool Heater offers efficient operation, fast heating and simple operation in a small, compact package, available from Pool Supplies Canada.
Thanks!
