Hi all,
I'm not really sure how to describe this issue, but hoping someone might have seen this before and can help point me in the right direction. I have an in-ground plaster SWCG pool, and this summer I noticed it would keep developing a brown spot on the wall. I could scrub it off, but it'd be back in a day or two. Looking at it underwater it almost appeared to be a brownish algae.
I let it go for awhile and it started to get pretty dark, and developed a ~4"x3" spot that was pretty stained, so I took some sandpaper to it and cleaned everything up. As I sanded it, it appeared to be a couple small blue-ish spots where the discoloration was coming from. I attempted to sand those away but it appeared to me that they were pretty deep or all the way through the plaster. So instead, I thought as a temporary fix I'd put some pool-repair epoxy on it and cover up the source of the issue.
However, to my amazement, the brownish stuff is now coming out through the epoxy. That's what I have photos
What in the world could this be, and/or how can I get it figured out and resolved? Here are a few photos, I apologize for the poor quality. If needed I'll drain the pool enough to get a better look at things...
