Thanks Justin. I’m using tablets exclusively with an occasional shock (lightly) with Bioguard Smart Shock.
Your answer prompts me to give my next installment on my adventure. I turned the maintenance over to a company, and they took care of everything except brushing. I looked at their chemistry reports and everything was within limits. I did however check and monitor the PH levels, and found that they would rise into the 8.0 zone if I didn’t continue to add muriatic acid regularly. And probably by regularly meant about a pint a day. I would comment about the acid demand to my PB but got no response back on it- meaning to me it must be normal. Finally, after buying cases of acid over the last 7-8 month,, I decided to become a chemist and truly learn about the test kit and water chemistry. Imagine my surprise when I found out I had a calcium hardness of 900. I stopped right there, went to a different pool store and got the news that yes, I had to drain the pool and replace the water. I’m in a rural area and on a well, so it could have been worse.
Since I had to drain the pool anyway, this was an opportunity to address a tiny rust spot in the plaster. The PB came out and did a great repair, but commented on the appearance of the plaster. It had a mottled appearance and hues of blue in it. The PB said that was from the heater’s heat exchanger. Also, there was some brown from iron in the water. Long story short(sort of), the heater gets bypassed, pool gets refilled and in goes 6 gallons of acid and a brush-o-rama for four days bringing the plaster to new appearance.
Now comes the raising of the PH. It took a ton of baking soda to get it back up. Now to test the water. PH is 7.4. Calcium is low- as expected. And the TA is about 340. What? Guess what? Half the water gets drained again. And yes, I have great well water with low metals (but I used metal magic to be safe). Refilled the pool and got the pH to 7.4, Calcium low, but am bringing it up to about 220 but the TA is at about 200. I plan to bring that down by the lower PH/aeration method, so I think my chemistry adventure is coming to a close- I hope.
So now that I have given the plaster another acid treatment, I suppose I should expect it to indicate as if it was a new pool, with dust showing with daily brushings for awhile??? Then it should diminish to next to nothing in about a month? And if it doesn’t? You see where I’m going with this, right? The second pool supply store mentioned there might be an issue with the plaster. In mentioning it (gently) to the PB, I got crickets. All I can do now is see if the acid demand continues and respond accordingly, but that won’t be daily acid addition.
So gang, there it is, my story. Sorry it was so long. Glad I found this place, and grateful for any help. I have also learned not to put my prized investment into the hands of anyone who didn’t pay for it.
Finally, regarding the chlorine, I’m going to switch from tablets to the forum’s recommendations. Thanks again for any and all help!
Bill
