I am renovating a 16x32 in ground pool 5' deep in the center about 17,000. Outside Chicago area. The pool has a main drain & skimmer and two returns. It had an 30 year old Hayward sand filter rated at 2.5 sq ft filter area and 50 GPM max pressure 50 psi and a Hayward 3/4 hp super pump. All fittings and piping are 1.5". I want to move from the sand filter to cartridge. I was looking at the Hayward star-clear plus line. I was told I should get a larger filter and was looking at the the C751 (cause the flow rate was a little larger than the current sand filter and still used 1.5" piping. A pool builder I was talking to said I could go much higher up to a 120 GPM filter. He also said that I should add a more returns and increase the return piping to 2" while keeping the suction at 1.5". I can get the 75 gpm, the 90 gpm, and the 120 gpm in wither 1.5 or 2" fittings. Never had any issue with the 1.5" piping, that I was aware of. Hayward says in their documents that 90 gmp and above should use 2" pipping. Would it help to add a 3rd return or go to 2" piping without adding a 3rd return? Is it OK to have 1.5" suction and 2" return? I have put a basic diagram of my pool and the old and new filter with potential 2" piping and a 3rd return. I hope it makes sense. Any and all suggestions would be greatly appreciated.
