Rattus Suffocatus
- Jun 5, 2019
- 1,713
- Plaster
- CircuPool Universal40
$350 probably isn't bad for that setup depending what brand this pump is, etc. I probably have $250 in my setup at least. As for force carbing.. you are correct that using a tank to do it is technically force carbing... but on the boards, etc. that is generally taken to do the "shake and bake method". I am the odd one who usually likes to sugar prime a keg. The reason why is that the yeast will "eat up" the remaining oxygen in the beer during this process. This is why I generally think the lodo guys are a little crazy, they will argue until they are blue in the face that it doesn't help at all when in fact it's about 1/3 of what they are doing overall. There are cases where this isn't practical or the beer sits too long (like a highly dry hopped IPA) and then going "artificial" is better. One other nice thing about sugar priming is that you use a lot less CO2 and don't need refills as often. Ultimately, you will "force carb" a little because in a keg you want to undershoot the volumes of CO2 a little and let the tank make up the difference for the same reason you don't want to overcarb when doing shake and bake... if you do it right you can drink right away but will make up the CO2 in a day or two for perfection.
Typically if I do a complete artificial carbonation, I will shake and bake a little in the beginning... and then I will hook up at pressure for a week. You can reverse the CO2 line in the keg like above, but I am lazy and that means you have to depressurize the keg at then end before serving which is messy. So alternatively, I'll shake it up a bit every day for that week or so and then at day 7 or 8 you are good to go...
The Mangrove Jacks M02 is going strong right now. It's behavior is odd compared to other yeasts I have used like D47, but as long as it cranks away... it cranks away. (I could have a leak somewhere on my fancy fermenter too but you don't worry about such things as long as it's going.) It seems to get good reviews. I will let you know. Though it looks like you will know anyway. I have been meaning to try that yeast since about 2015....
One thing that is nice about cider in 2020, is that almost all brands now are Pasteurized and it's now hard to find one with sulfates in it. It used to be the other way around, only a couple of years ago. Musselman's at $5 gallon used to be the only reliable way to go (it's still the best commercial mass produced cider though). If this works then two of those and four of the Walmart brand (3 qt) might be my new quick cider recipe.. That and a cup of sugar boiled in water.... That brings a batch down to $5/gal or so which is nice...
