- May 23, 2015
- 25,704
- Plaster
- Pentair Intellichlor IC-60
Swamp woman,
This looks like a failure of the testing kit. I know everyone that owns an aquarium thinks their chemical tests are adequate for pools but I almost never trust result when I hear the phrase, "I used my aquarium test kit..." Now I give you A LOT more credit because I know you are skilled in this stuff but I think you're running into some kind of testing error. Doing large scale dilutions is always problematic because the errors can pile up very quickly.
Would you consider sending your water out to a professional testing lab to get it checked? They should be able to give you an accurate phosphate analysis.
Also, I know of nothing that says phosphate removers need CH. The reaction is lanthanum chloride [EDIT- I accidentally wrote phosphate instead of chloride in my original post-END EDIT] gets converted to lanthanum carbonate and then to lanthanum phosphate. Calcium is not required for the reaction to occur.
