Saturn94
- Mar 11, 2015
- 1,864
- Vinyl
- Hayward Aqua Rite (T-15)
As for Hanna, the calibration standards are for checking the meter INDEPENDENT of your pool water to make sure the LED light source and photodiode are working properly. Your pool water, tap water, etc, would be unreliable for that process.
The HI 713 and HI 717 Checker®HC’s are extremely simple to use. First, zero the instrument with your water sample. Next, add the reagents. Last, place the vial into the Checker®HC, press the button and read the results. It’s that easy.
REAGENTS AND STANDARDS
HI 717-11 Calibration checking set (0.0 and 15.0 ppm phosphate)
Swampwoman,
Now that you will be running an SWG, you are going to want to actively monitor your CSI as an important parameter for cell health. SWGs work best when your CSI is a bit negative. I keep my CSI near -0.1 to help keep the cell scale free. Operating at a lower pH like you do is a good thing.
Orthophosphate at concentrations greater than 25 ppm will precipitate as silver phosphate to cause positive interference. This can be prevented by diluting orthophosphate concentrations below 25 ppm with DI water. Bromide, iodide, and cyanide at all levels titrate as equivalent chloride concentrations. Sulfide, thiosulfate, and sulfite interfere but can be removed by treatment with hydrogen peroxide.
But in reality, these units ( ref to SWG) are more like small chlorine factories that take in salty pool water and output chlorine. Inside the factory, however, work proceeds under some rather extreme conditions. At some points inside the generator, chlorine concentrations can reach 50 ppm (the normal recommended level for pool water is a maximum of 4 ppm), pH can be either close to 14 or 0 (normal levels are between 7.2 and 7.8) and temperatures can exceed 120 degrees.
At a pH of 14 it's 0.00169ppm of PO4 and at 0 it's 2,133,044ppm of PO4. And for a minute I was thinking that at 2,133,044ppm of PO4 there's nothing to worry about but I had the cathode and anode mixed up where at the cathode it's 0.00169ppm PO4. So why don't we all have a PO4 scale issue and mixing up the cathode and anode is one answer as in a self cleaning cell the cathode and anode are interchangeable. ie. constantly switching. I have know idea what the frequency is.PO4 = 10^[11.755 - log(375) - 2log(26.67) - (0.65 * 7.5)] = 28.44 ppm = 28,440 ppb phosphate.
Atlas and Bartha 1998 in Microbial Ecology said:Phosphate is required for microbial generation of ATP and for nucleic acid and membrane phospholipid synthesis. High concentrations of phosphate, however, may inhibit microbial growth. Concentrations of available nitrogen and phosphorous often limit both productivity and decomposition in aquatic habitats. Additions of of available nitrogen and phosphorus are often used to increase productivity in aquaculture practices. The elimination of the phosphate limitation is sometimes undesirable, as it can lead to prolific algal or cyanobacterial growth. This growth has occurred following addition of phosphates, in the form of household detergents, to lakes where productivity was phosphate limited.
Jack's magic purple also has something in it that is supposed to clean the cell.
I suspect it has something to do with blocking or interfering with the movement of nutrients across the cell wall.Ps fascinating about the po4 limiting level...wonder what it IS!
