PH vs alkalility increaser
Yup! First and foremost is pool owner testing. We've found that pool store testing is often (more than you'd think!) inaccurate due to a variety of reasons, yet no one is going to be as concerned with accuracy more than the pool owner.
Which means you need a GOOD test kit and there are only two we endorse. The TF-100 (my personal fave) or the Taylor K-2006C. Both can be found at tftestkits.net
The TF-100 runs about $70 but will save you much more because you won't mistakenly be adding chemicals you don't need!
We need to know (and these kits will tell you):
FC
CC
pH
TA
CH
CYA
Please consider getting one ASAP and we'll walk you thru all the tests and the results.
Also go dig in to PoolSchool!
Maddie :flower:
S,
Here is a good place to start...
TFPC for Beginners (I fixed the bad link... Oops..)
Read the link and then start asking questions...
We believe in never adding anything to your pool without knowing first exactly what to expect...
My question for you is... what was your TA reading at the pool store before they told you to add alkalinity up?????
We don't normally tell anyone to increase TA unless it is below 50....
Shar47 welcome!
Please ask any and all questions. We were all once newbies like you. So no question is out of bounds.
Make the TFP crowd happy and replace "Test with chlorine and ph tester and have water tested at pool store also" with "TF-100 on order" :handwave:
Thanks, Maddie! I just ordered the TF-100.
:goodjob::party:
Read Pool school until you feel like :crazy:
Once your test kit arrives and you start doing, it will make start to make sense. Two, three weeks and you'll be a pro at testing and already have a pretty good idea of what does what and even roughly how much you'll need. By the time school lets out, your pool will be clearer and more sparkling than you thought possible. No smell, no itchy skin, no burning eyes, no cloudiness, no green. I kid you not.
