pH increasing super fast on 2 month old plaster
SuperMiguel
139
Florida
Hello, is it normally for my pH to increase from lets say 7.2 to 7.6 in a day? been happening alot and been using a ton of acid...
Also my water tastes very weird its like salty but not really, hard to explain, but it tastes funny. Here are my test results from saturday:
FC 1.0 (working on this increased % on chlorination)
pH 7.2
TA 50
CH 350
CYA 40
Salt 3200
Yes it may be normal in a newer plaster pool, water with moderate to high Total Alkalynity and also a waterfall feature or attached spa spill-over. Do you use a test kit and know your TA ppm? I see you run a SWCG so your salty water taste makes perfect sense.
attached spa spill-over increases pH? Also i was under impression that SWCG wouldnt cause salty water since it was very small amounts of salt
