The last test results you logged in PoolMath were from April 6 - over 4 months ago. If you haven't done a drain/refill since, your CH is probably above 1600. You can easily manage CH to around 1000. Being you are well above that, a water exchange is in your near future. Of course, it's way too hot for that right now. Once the daytime temps get in the upper 70's to low 80's, plan for a full drain refill. Your fill water most likely has a CH of 250 and TA around 110.
Post a complete set of current test results... including water temp and salt level. What test kit are you using? What are you using to test salt level?
For now, keep the pH around 7.2-7.4. Once it gets to 7.4, lower to 7.2. Let the TA drop to 60. TA of 80 will let the pH climb faster. Keeping the pH in the 7.2-7.4 range and TA 60 will help minimize SWG scale buildup. With your CH as high as it is, you may still get some scale buildup. It would help to minimize the spa overflow (keeping aeration to a minimum) - in reality, it probably only needs to overflow 30-60 minutes a day. How long are you running your pump per day?
As was mentioned, look into a water softener and plumb it into your pool refill line. Either that or plan on replacing your pool water every 2 years or so. Here in the valley, your entire pool volume or more can evaporate in a year - and the CH does NOT evaporate with it.
