Since I'm colorblind, doing the pH test in the TF-100-PRO test kit is hard for me. So I bought an $80 digital pH test by the recommendation of someone on this site. I'm finding that my pH is going up regularly. On early Monday morning, pH was 8.3, and I added about 45 oz. (of 31.45% muriatic acid) based on Pool Math to hit a target of 7.6. Checked it today, it was 8.2. So Pool Math told me to add 60 oz of 31.45% muriatic acid to hit a 7.4 target or so, so I added the 60 oz worth of MA. My pool is between 32,000 and 34,000 gallons. Is this fairly normal that pH might be hard to keep down and am I doing the right thing based on the pH readings I'm getting by just adding the MA as often as I need? it's been really hot and sunny for 10 days straight now.
I -think- my TA is around 90 to 120, but again, my color blindness makes doing a TA test really hard to do for my eyes. I mention this cause i think having a higher TA make drift of pH less likely? (or is it vice versa).
(Everything else looks really good. FC, CYA, etc. and water is crystal clear.)
