My pool is about a year old and had high TA a few months ago so I tried to bring it down, which I did successfully. At this point the only chemicals I've only used was trichlor, liquid chlorine, and muriatic acid.
Then my TA was dropping (60) below my target range (70-90) because I was adding MA to keep pH within range, so I began using baking soda to bring it to 80 TA.
But I noticed at 60 TA, pH was more stable and at 80 TA, pH drifted up.
Is low alkalinity bad?
Is it secondary to controlling pH?
Can I keep TA lower than the recommendation since 60 TA is stable for my pH?
Check out my PoolMath logs for additional information
