Hello all,
I had a new heat pump installed at the end of May. I've been keeping a solar cover on when not in use to try to keep the heat pump efficient. My pH seems to dropping pretty consistently to a 6.8 - 7.0 level not too long after I raise it, which I've done with both soda ash at times and baking soda at others.
My current readings are
FC 1.66
TC 2.24
pH 6.8
TA 109
CYA 29
I've been reading a lot about raising the pH by aeratinf, so giving a few tricks I found on here a try. Currently have a sump in the pool near the top trying to aerate. Also going to try to create (or buy) some type of makeshift PVC fountain that will screw into the return to bring the water our of the pool a bit.
I have a few questions:
-Trying to figure out why the pH keeps dropping. Would more use cause this, or maybe having the cover on a lot?
-If I get some kind of permanent (or even occasional) fountain type mechanism on my return, I think I'll need to try to balance usage of it with the efficiency of the heat pump. Is that assumption correct? Any tips on that?
-Would an inline aerator be a better approach to have less work around balancing with the efficiency of the heat pump?
Mike
FC 1.66
TC 2.24
pH 6.8
TA 109
CYA 29
Mike
