Has anyone in the forum recently calibrated the pen type pH meter that comes as an option with the TF 100 test kit?
Hi there. I have two beaker solutions with 250 ml deionized water and the entire 4.01 and 6.86 pH packets dissolved (the ones that come with the meter). The instructions say to immerse in the 6.86 and adjust the pH reading on the meter to what the chart says for your room temperature. My room temperature after sitting inside for two hours is 19°C so I adjusted to 6.88. Then the instructions say to put it into the 4.01 solution for at least a minute until it reaches that pH. And it just sits there at 3.5. It’s supposed to read 4.0 @ 19°C.What is your problem with calibrating the pH meter?
I had actually considered that possibility and it makes sense. I’m familiar with 2 and 3 point calibrations. Well, I’ll take that as a win then and go ahead and dispose of the solutions. Thank you.Calibration at pH 4.0 does not matter for pool water that only ranges from 7.0 to the low 8's.
Calibrating with pH 7.0 or 6.86 is the best you can do.
There are better pH meters like the Apera that do automatic 2 point and 3 point calibration.
Hi. I have had very bad luck with this pen. Batteries die quickly and I’m just wondering if there’s something a little better maybe uses AAA batteries or something? but I don’t like my drop test either.Has anyone in the forum recently calibrated the pen type pH meter that comes as an option with the TF 100 test kit?
I purchased the pH meter along with the TFP test kit and unfortunately I don’t like it. The batteries die really fast and that’s a negative for me. I need one that maybe has an auto shut off or something like that. What kind of batteries do these PH60 meters take? I already have a huge amount of the calibration solutions that I have purchased for all three points. I just want more detail between 7.5 and greater than 8.2. I want to know how bad it is or how close I am to the mid range. I just can’t tell with the colors on the drop test. I did go down to four drops and it helped but I just seems like I’m always guessing between 7.8 and, however amount it’s over 8.2.Yep, the PH60 is great. Storage solution is essential from my experience, since I have started using that the calibration is very stable.
Calibration ideally at 7, 4 and 10, but 10 is more important than 4 with a TFP pool. If your pH is never below 7, then calibration at 4 doesn't add much. You could just keep the pH 4 calibration solution that comes with it sealed until the day you need it. Should probably last that way until the probe needs to be replaced.
pH meters are great when properly looked after, including regular calibration and proper storage. A lot more expensive than the drop test, and more care required, but have some advantages when maintaining pH close to 8 or FC above 10.
I’m having a lot of trouble getting it down to 7.5. I have been using an old bottle of MA. It’s done now and I’ll be buying a new one so who knows maybe it’s not as potent as it could be. That’s a big guess though.
I’m not testing TA before adding MA. I hadn’t picked up that testing tidbit along the way :/ 7.5 is not important to me however getting further away from 8.2 is and most of the time I can’t seem to be certain it’s less than 8.2. Occasionally, I can see that it’s 7.8 or a little bit higher, but I’m so paranoid that it’s too far over 8.2. I am having trouble at that Range visually.Why?
It does not make a lot of difference if your pH is 7.5 or 7.8. pH dirfts around hour to hour and day to day.
Any pH in the 7's is ok.
Why must the pH be 7.5 for you?
What is your TA? Your PoolMath log does not show you testing TA before adding MA.
4 AAAs.What kind of batteries do these PH60 meters take?
Good morning. I read the article on TA/pH relationship. I did test my TA this morning and it is 70. Also the pH is down around 7.9 or eight without doing anything. So I think I need to just relax a little bit on the pH, not worry so much about it other than in range. Don’t need to spend an extra hundred dollars on pH meter if I can avoid it. I did test my CYA again this morning and I think it is around 40. Which leads me into another question which probably requires a new thread. It’s about CYA, and floating tablets. I may have to start using a combination of liquid chlorine and tablets due to travel schedule. ;/I’m not testing TA before adding MA. I hadn’t picked up that testing tidbit along the way :/ 7.5 is not important to me however getting further away from 8.2 is and most of the time I can’t seem to be certain it’s less than 8.2. Occasionally, I can see that it’s 7.8 or a little bit higher, but I’m so paranoid that it’s too far over 8.2. I am having trouble at that Range visually.
