Hi All, and thanks for reading,
13,000 gallon gunite kidney shaped pool. Stonescapes mini pebble redone in 2017.
I believe my CYA levels are too high but before draining out some water, wanted to check here first.
Using TFP test kit and included Taylor kit for chlorine and PH
Water Temp = 60-62
Just cleaned pool filter cartridges
Cl level is just above Taylor's top marker of 5.
Ph level is 7.4
CYA is somewhere between 70-80 depending on who is looking down the tube.
FC=3.5
CC=1
I have some patches of mustard algae cropping up on the face of steps in the shallows. I check chemicals every other day, and normally brush 1 - 2 times weekly, and this is usually enough. Now however the mustard algae, is coming back every couple days.
My plan is to drain about 50% of the water and re-balance the chemicals, keeping the CYA on the lower side. Before I go through the draining and refilling process, I wanted to check in here, to see if I'm on the right track.
Water Temp = 60-62
Ph level is 7.4
FC=3.5
CC=1
