- Jun 13, 2013
- 224
So, for about a year now I have been having issues with persistent fine silt building up at the bottom of my pool.
I can vacuum it up, but a day later it’s once again right back where it started.
On a few occasions I’ve vacuumed to waste which solves the problem, however given it’s only a 12x16x4 inground it ends up consuming a surprising amount of water (Even with the VSP on a low-ish speed sufficient to vacuum) that then needs to be replaced with fresh (and very cold) water. And then usually within a week or three, it’s back anyways.
The root of the problem seems to be debris not getting caught by my sand filter - question is, why.
I’ve tried DE to no avail.
Sand was last changed about 3 years ago and we only have a 5 month pool season here so I don’t think that’s the issue.
Are there any super fine filtering skimmer sock solutions or something that could be used during vacuuming to remove this debris before it simply gets sucked up by the vacuum and then eventually blown right back into the pool?
My water is otherwise crystal clear, no issues.
Thanks everyone.
Thanks everyone.
