Folks, I'm new to forum but need some help and better understanding of abg chemistry. I have owned a bestway 13x9 oval for a couple years and continue to battle algae and cloudy water. I have also owned homes with in ground plaster pools before and never quite experienced the algae problem in those pools. So...using various pool test kits and strips, I monitor the chlorine and ph regularly. I use a chlorine floater with the chloric tablets as well as casting chloric shock granules now and then, and in an effort to clear water. When pool is freshly filled, it will remain clear for up to two weeks, but gradually begin to cloud, and with filter running, a material that looks like sand coagulates on the bottom. This stuff disperses into water if brushed and the water clouds. Running the filter 24/7 does not clear the water. I have tried green algae treatment chemical, chloric water clarifier, heavy chlorination....nothing clears the water except draining it and refilling. When I drain it, a residue of algae is mopped up off the liner bottom. It smells like the algae on the bottom of a boat left in the water. I know that smell. So......what is going on??? Which chlorination product and method works best...and why doesn't shock treatment or continuous filtration have a positive effect?
