Got a weird situation that just occurred. My Pentar Salt cell was showing red, low salt, but last week I had the water tested at the pool service I use and it did test a little low but not bad. Recommended 80 pounds of salt be added because we have had a lot of rain. The cell still showed red so I decided it might need to be cleaned. Pulled it out and sure enough it had a lot of mineral build up. Did the standard clean about 3 times to get it all out. Hooked everything back up and no lights. The circuit button inside the easy touch is ok. Double checked the cord connection to the easy touch panel. Seemed to be ok but unhooked it and remconnected to make sure it was a good connection. Nothing so I tripped the main breakers again inside the easy touch and noticed the lights on the cell would flicker on but go right back off. The status light inside the panel is green so thinking I have a loose connection somewhere. Didn’t want to start removing the front plate to the easy touch until I talked to you guys. Is it possible something is loose between the 4 prong connection on the box and something inside?
