I have a call into Marina regarding my 2.5 yr old Pentair Warrior SE but I wanted to check here as well if there was anyone familiar with an easy fix. It seems to me that the directional actuator is not working. When I do a powerup test out of the water, the actuator doesn't move but the drive and impeller seem fine. The first symptom I noticed was that the robot never really changed directions in the pool....just back and forth over the same general area. I took it apart and can move the actuator manually, turned it to one side and now the robot turns all of the time, and won't climb the walls. I also no longer see the flow of water to the surface.
For those folks who have opened up their motor, is there any chance the actuator is user replaceable?
FWIW, I have a screened pool and only run the robot every 4-6 weeks, keeping it out of the pool in between. I don't really want to calculate the "cost per cleaning" if I have to replace the $450 motor.
