- Dec 26, 2019
- 1,995
- Plaster
- Pentair Intellichlor IC-40
Looks like I have a shaft seal failing on my pump. Pad is wet underneath the pump in a nice fashion that indicates it is leaking out from the motor/pump seam on the unit. I am going to try and get the PB to repair under warranty, since the pump is only just over 2 years old. But if they won't for some reason, what else should I replace while I have it broken down? I figure if I'm going to tear into it, replace anything that might need to be, as long as the parts are not ridiculously costly.
--Jeff
--Jeff
