I think you would need one or the other... both will work....
the RS 485 will control the pump through your automation (I would call inyo and ask exactly how that works)
The other way using the wire from your valve would just use the onboard pump values and change when it receives power from the valve... ( this is the way I went with my SWG as it was too easy )
