I'm curious how accurate the pentair intellicenter/app is at estimating watts being used by a variable speed pump. Has anyone verified if the estimated power (watts) listed in the app are close to actual power (watts) used?
I wonder if these numbers are based on a certain amount of friction loss in the plumbing. Surely the pumps power usage at a given RPM varies somewhat based on load.
I'm asking because I would like to build a spreadsheet to calculate approximate cost to run my pumps at different speeds. I'm somewhat skeptical of any numbers provided by a manufacturer because the real world conditions are often different than perfect conditions on a test bench.
I might need to just get a current meter to just test real world conditions unless someone here know how accurate these pentair estimated numbers are.
Thanks in advance!
Thanks in advance!
