- Mar 10, 2013
- 82
Hi all, I just had a Pentair Superflo variable speed pump installed. Before I had a single speed pump on an intermatic timer.
The issue is with the Pentair it goes on and off based on programming, so if I want to run my pool heater overnight I would need to reprogram it to stay on and then reprogram it again the next day. Seems kind of crazy is there some work around?
Also at 1500 rpm theres not enough flow for the heater to work, which I find odd as I've seen people state at 1200 rpm their heater works.
