I notice that when I lose power my pump clock reverts back to 12:00am but all the other programs stay the same. Anyone else had this issue as well?
Actually the 011018 pump has a track record that makes it one of, if not the most reliable VS pump on the market. Pentair reduced the warranty because the 011018 isn't their top of the line pump any longer. They only give three years on the top line pumps. The 011018 is being discounted online now in the eight hundred dollar range. Drive failures are by far the biggest issue with all VS pumps. Most are caused by power surges. Anyone adding a VS pump should also put in whole house surge protectors. The pump is a computer connected to a high power motor, placed outdoors and powered through a long feed circuit. Gee, what could go wrong there?
Come on, that is not acceptable. In this day and age, a device can not function outdoors? Proper enclosure and transformers especially at that price point. What about air conditioners and heat pumps? At least heat pumps have onboard motherboards for programming.
He didn't say it can't be operated outdoors. His point was that it is susceptible to power surges and that a surge protector should be used to help prevent that. As he said, the 011018 is by far the most popular pump on TFP and there are very few reports of failure with most being related to power surges. Mine is on its 6th summer of flawless performance and I'll buy another one without hesitation.
The fact that they want to analyze the cause of the failure, just shows concern for the quality of the product. There are many thousands of pool owners here and, as was noted, this is the most popular VS pump with very few failures reported. This is the very first failure of a pump timer, were it fails to maintain current time that I have ever seen. Although drive failures do occasionally occur, this would appear to be a rather rare type.
Many pool owners here, including myself, have had a Pentair Intelliflo pump in service for many years without any problems whatsoever. You, on the other hand, have a total sample size on one. You did have a problem of and unusual nature. Pentair has repaired your pump under warranty and is analyzing the cause to prevent future failures of this type. I don't see any complaint you could have, that would warrant warning people to not buy Pentair pumps. Nor do I see any evidence that "They are knowingly selling problematic variable speed pumps and not informing their customers".
The pump drive is the part most prone to failure, and you now have a pump that's three years old, with a brand new drive on it. Admittedly, it's the same drive you had originally, and the same one every other Intelliflo 011018 has. Pentair sold you a pump with a three year warranty. You had a problem. They honored the warranty. Just count yourself lucky that the problem didn't occur a month after the warranty expired.
I'm happy with my five year old Intelliflo with a five year old drive on it, and you are complaining because your three year old pump has a brand new drive. Sorry, I just fail to see what Pentair did wrong. I'm guessing you want them to extend your warranty, beyond the three years, because you had a problem. That's not how warranties work. Pumps are cheap compared to cars, but tell your dealer you want a couple years tacked on to the warranty and see the response.
Agree to disagree, I'm out.
