Wanting to replace the original sand filter. I doubt the sand has been replaced in the past decade or two possibly.
I thought about a TR60 but then started leaning towards the TR100 (bigger is better, right?). But then I read this in the manual...
The plumbing from my pool to the pump is 2" but then is 1.5" from the pump to the filter's slide valve. Also, from the filter's slide valve to the in-floor cleaning system is 1.5".
I need some help/input on picking out a proper sand filter. Will the TR60 hinder the in-floor cleaning system?
My signature should have additional info about the pool.
"Long piping runs and elbows restrict flow. For best efficiency, use the fewest possible number of fittings, and
large diameter pipe (at least 2” for TR100).
