CJadamec
Agreed it looks good. For the pump control wire.
The surge protector should be wired to its own dual pole breaker and not connected directly to the pump as far as I know. Can you tell me the brand and model of surge protector you used?
You should zip tie the low voltage wire away from all of the 110/220v wiring and bus bars tho. You don't want them touching each other if you can help it.
