I have seen a couple posts made regarding using a Pentair pump with Hayward control. We have recently purchased a Pentair SuperFlo VS and we have an existing Hayward AquaPlus automation system. I also purchased the 6 wire Pentair data cable and a Pentair IntelliComm II. I called Pentair support on 5/18 and the technician told me I did not need the Intellicomm II that the 6 wire data cable could run to each of the relays directly without the Intellicomm II. So, I rewired the data cable as shown on pg 5 of the SuperFlo VS Installation Guide and Users Manual. It seems to work a bit better than when I was trying with the Intellicomm. I can turn the pump off and on with AquaPlus, but the pump does not seem to be coming on with the correct speed as selected. I have speed 1 wired to main relay, speed 2 to Aux 1 and speed 3 to Aux 2. Also, our salt cell does not seem to be reading the salt level correctly (I am assuming that is a result of the pump not running correctly - as the single speed was previously set up in the Timers Menu). I did try to walk through the VSP setup in AquaPlus over the weekend, to get the automation system recognizing that the pump is now a variable speed and that the additional two speeds are controlled through Aux 1 and Aux 2. Not sure if I have that all correct yet. Prior to the reprogramming we were receiving an error code of 22 on the pump. The other question I had was regarding the power wiring of the new VS pump, initially I had it wired to the main relay on the AquaPlus, then I saw on numerous posts and asked during my call with Pentair to find that it needs to be wired direct to the breaker, but when I did that and activated the relay the pump did not turn on, so I put the wiring back as it was, into the main relay, and was able to get the pump to go on. During that change in power wiring we were receiving a error code F on the pump. I currently have the data cable disconnected and I am running the pump via the outside control on the pump itself. I was hoping that you might be able to point me to items to check or resources I could call. We are in Puerto Rico and support and service here can be a real challenge. I had a Pentair authorized dealer come out to install the new equipment and they were kind of dumbfounded as to what had to be done - not instilling my confidence. We had a friend that does a lot of pool maintenance help us and connect the new pump and filter and they are installed well, now it is just a matter of getting the automation system to communicate with the VS pump. Any help is greatly appreciated!
