Can someone tell me if this is normal?
We had our PB install waterfalls. They're driven by a Pentair Superflo VST. We rarely use the waterfall feature. Last week I turned them on for a first time in a long time and no water came out. I checked and the Superflo basket had no water in it. I turned off the system, released pressure, opened the filter and water rushed in and filled the basket completely. So I closed the top, restated the system, and the waterfalls worked again. Except I noticed the Superflo basket was empty of water again. The pump sounds fine but I'm not sure this indicates air in the system?
Photo attached. Red arrow points to the Superflo VST waterfall pump. Green arrow points to the Superflo VSF filter pump.
Thank you.
Thank you.
