Pentair Superflo VS won't power on
cmr
0
Nov 19, 2016
6
LIVERMORE
Pump stopped working, LEDs for speed and duration flashing properly, but pump does not come on,
Cycled power at the breakers and fault light comes on for a while then goes out, after it goes out I am able to re-start pump for a while and then is shuts down and fault light comes back on (solid)
Sometime after I cycle power pump returns to normal operation for a few days and then shuts off and LEDs for speed/duration still flash normally
tried reset +/- step one
also reset to factory defaluts
Is there anything else I can do ?
Do I need to send pump back to Pentair for service ?
please help
serial 305130035
350879.a was on the motor label
will have to check again for numbers listed above
user guide part number is 350880
ser 3051300358
sorry for typo
purchased 6/8/2014
That motor is interesting because it can accept 99-253V, 50/60Hz input power. Check voltage under load if you're comfortable doing that.
Check the shaft to see if it spins freely. Access from the back where there is a hole in the fan cover. It should take a flat screwdriver or a 5/16 Allen wrench.
Is the motor black or almond?
Is there a digital display?
That's a 342000. Probably need to call Pentair.
I think that Century makes the motor. Maybe they can help.
That motor only takes 240 volts. Make sure that it's getting 240 while running.
