Hello - I recently upgrade my control panel to the Intellicenter Control System with Screen Logic. Now the only way I can get my filter pump (Superflo VS) to run is when I put the system in service mode and then manually run it from the pump panel. My (2) older single speed pumps (WhisperFlo) work just fine through the panel. Is it a set up issue within screen logic?? Thanks in advance!
