GFCI breakers/outlets don't last forever, either. Have you tested yours recently?It is GFCI protected 120 volts. Can you suggest one from Amazon? Thank you.
That doesn't sound right. Typically the transformer is well away from the light fixture, usually at the pad. That's what makes the low-voltage light much safer, because only 12V is running through the wire from the pad to the light niche. Anything like this at your pad? If so, you might be able to run both lights off of it.My Spa light is 12v. It must have the transformer built into its housing.
That's what I have. The old skool floodlight lasts forever unlike the fancy / expensive LED lights. If you want to make them fancy, color changing LED bulbs are around $100 each and much less of hit when they blow every year or two."Pentair Amerlite"
My recommendation is replace the light. You don't usually get a second chance with pool water, electricity leaking from a light, and you or your family. There are constant recommendations to not trust a flow switch to protect a SWG. Why trust a GFCI with one's life? It's the last line of defense and they fail as well, especially if in pools, as is almost always the case, it isn't replaced every 5 years as most manufacturers will tell you if you look deep enough into their literature.Perhaps @1poolman1 might have some suggestions. But here's another point of view.
Is yours a 12V or 120V light? If you were visiting a friend and he told you he fixed his 120V pool light with some caulk, would you want to swim in his pool? Conversely, if you later found out that your "friend" recently fixed his pool light with some caulk, and let you swim in his pool without telling you, would he still be your friend?
DIY plumbing, and many other pool equipment repairs, if done wrong, would have no life-threatening consequences. An incorrect pool light repair is not one of those. The fact that you don't know how to do it, but might attempt it based on the word of a random internet stranger, should tell you all you need to know about attempting this repair yourself.
How much is your family's and friends' safety worth? Less than the cost of a new pool light?
There are some on Amazon for as little as $200. Some of those are low voltage, and even multi-colored. So for a few bills, you could upgrade to a much safer, much nicer light. The peace of mind would be just a free bonus.
FYI: one of the most well-respected pool electrical experts, Mike Holt, won't put a pool light in his pool.
Pool Safety Sanity Check
CLICK HERE to read the customer's complete letter including Mike Holt's comments. Please share this newsletter.www.mikeholt.com
Its a Pentair, or American Pool Products if it is very old, Amerilite. That is the standard for pool lights.I am ready to replace the light. I just don’t know what size I need.
View attachment 612703View attachment 612703Is this a 10” light?
