Pentair PL4/PSL4 Convert to Salt Water
jkmccurdy
0
4
Hello,
I am looking for advice on the best way to convert our pool to a saltwater system. I would like to do this myself using our existing equipment, if possible. Any suggestions for doing this?
John
Hi, I have been looking a little more at other SWG's. I was looking at the "CircuPool RJ-30 PLUS Salt Chlorine Generator" and found the thread below as well.
Can I do the same type of connection as the thread above?
Attaching pics.
Thank you for the help.
John,
If you get the IntelliChlor, your can adjust the cell's out from ScreenLogic.. You can also see the reported salt level of your pool water in ScreenLogic..
You can't do those things with an off-brand cell...
You can wire the power to the off-brand cell through the Pump/Filter relay, but that is about it. This will keep the cell shut off if the pump is not scheduled to be running.
