I have a new pool being installed, and the pool has two pentair micro brite led lights. I noticed a leak from the conduit from one of the lights, and upon further inspection I noticed another piece of pvc conduit seems to have not had the joint glued enough and is dripping water.
Should the lights be watertight not allowing water into the conduit? I am sure the water can somewhat be removed from the conduit when the one fitting is repaired.
It wouldn’t be an issue if the lights should be watertight and the conduit shouldn’t hold water.
Final question is the frost zone in my area is 4’ and the conduit follows on top of the concrete fitting about 38” below the pool walls. If this holds water won't it freeze and potentially break?
Thank you!
Thank you!
